Bottom painting a 21'
Mar 7, 2013
30
Sirius 21 Belews Lake
I am planning to put my 1985 21' Sirius in a brackish wet slip for 6-8 month. It has an old flaky bottom coat on it now and i think it previously was only docked in freshwater.I've been launching from the trailer since ive owned it but I'm looking to get more sailing time by keeping it in the water this year.
So i called the Marina and they will apply a ablative coat for $500+/-. I could possibly do the job myself. Elbow grease is free and i already have the paint, Seahawks Cukote.
My big question is whether it need a barrier coat or not. I can't definitively tell if it has one already. I can make out a white coating at the water line that is under the old blue ablative. From what ive read, barriers coats are usually grey or color. Im thinking it may just be a single primer coat. And on the bottom where the old blue has worn off it just looks like gel coat. I see no blisters or damage to the hull anywhere though.How can i really tell if it has a barrier coat already. Do i really need to worry about it for only keeping it wet for half a year.
Im pinching pennies to make my sailing dream come true. I got a great deal on the boat for $2500 in excellent condition. Now im frustrated that i might have to spend almost that on just bottom work.
Thanks again for your advice. This community is amazing.
Rich M
Nov 5, 2007
74
Hunter 28.5 Annapolis, MD
Based on the information you provided if it were my boat I'd sand the bottom with a medium grit paper to ensure adhesion, paint it, put it in the water and ENJOY the sailing season.
Mar 7, 2013
30
I'm hoping i can do that without causing any issues. I've never kept a boat in the water. I keep reading stories about blisters. Is that something thats happens over years or could it happen in 6 months? I guess I'm also just wondering if its common practice to bottom paint without a barrier coat. I mean whats the chances that I would get a boat that was painted without a barrier?
Jan 31, 2015
5
Schock Santana 30/30 Housatonic Boat Club, Stratford
If you only have minor flaking of the old bottom paint and the fiberglass underneath is solid you probably don't need a barrier coat. Just scuff up the bare spots, wipe with solvent, and put your bottom paint on. Only need barrier coat if bad blisters and/or large scuffs in the gel coat. If you have to do barrier coat, it's a lot of work sanding off all the old bottom paint and fairing them bottom, then at least 4 coats of 2 part epoxy, but not a horrible task.
Joe
Jun 1, 2004
8,346
You're worrying way too much. Follow the instructions on the can of bottom paint you own.... do it yourself.... and save 400 bucks... you'll spend some money on supplies and jacking your boat up... but that's it.
At the end of the season, you can inspect the bottom when you haul it out and see if any thing has happened.. which it probably won't.
Just a heads up, even with anti fouling paint... you will get some growth.. mostly algae.. so it's not a bad idea every month or so to grab a piece of old carpet, pull the boat into shallow water, or don the mask and snorkel, and wipe it off... If it's wet it comes off easily... if you wait till you haul out the boat and it gets dry... it's way more difficult to remove.
BobM
Jun 10, 2004
3,269
S2 9.2A Winthrop, MA
Be prepared to get your hands dirty or sell the boat. Marinas will just do a lousy job and take your money. Ablative is very forgiving. Keep in mind that the paint flakes are toxic so use a dust mask, drop clothes and perhaps a shop vac if it is really flaking badly.
Mar 7, 2013
30
Yes I'm in NC. Planning on keeping the boat on the Neuse near New Bern. Thanks for all the feedback. Looks like im bout to get dirty. I've done a little sanding on it and wow what a mess. I think I'll enclose it with plastic and put an ac filter and a big fan at one end. I'm chomping at the bit to get back in the water and I'm anxious to join the sailing community around New Bern and Oriental.
Sep 8, 2014
2,551
I just completed a full bottom job/blister repair on a 22 ft boat, and yes, it is a horrible job. If your gelcoat is present and not damaged you should be just fine. Most people will probably argue that gelcoat itself is NOT a barrier coat because polyester resin based gelcoat is not really waterproof... Technical arguments aside, it takes years of being in the water for water molecules to permeate through gelcoat and become trapped between the fiberglass and gelcoat or deeper in the glass to cause blisters. Since your boat was probably trailered most of its life it has always had plenty of time to dry out between water time.
So I echo the suggestions above, wear a mask and eye protection, scrape away loose flakes and then sand with medium grit paper... apply your new bottom paint and go enjoy the season. Your boat won't be sitting in the water long enough to absorb water through the gelcoat before you pull it back out.
Oct 24, 2010
2,405
Hunter 30 Everett, WA
I connect my orbital sander to a shop vac. I just remove the dust bag and duct tape a vac hose to it. Very little dust escapes.
Also cleaning the boat in the water is illegal in many areas (like where I live.) You may want to know before you expose yourself to legal problems.
Ken
Feb 26, 2011
1,440
Achilles SD-130 Alameda, CA
Umm... Not really.
In Washington, cleaning of ablative paints is forbidden. Otherwise, anything goes. No other state has restrictions on in-water hull cleaning. The Port of San Diego has implemented an edict that professional hull cleaners cannot create a "plume" of color while cleaning. Which in essence means they cannot clean ablatives. Boat owners doing their own cleaning are not restricted however. They can do whatever they like in this regard.
There are no other government restrictions anywhere else in the country, at this time. Individual marinas may have policies concerning in-water hull cleaning, but these do not involve any legal issues.
-na -NA Anywhere USA
Slogfish;
Are you working on your boat across the river from Newbern in the do it yourself yard where the old men sit and drink coffee in the office? My email address is davecondon@mindspring.com and I know the area of Newbern and Oriental all too well. They know me as Crazy Dave
Jun 2, 2004
1,956
Oday Day Sailer Wareham, MA
The only problem that I can see is what kind of paint is on the boat now? Some paints are not compatable with old finishes and may cause the old coating to flake off, leaving bare patches on the boat. This is mostly a problem only when applying a "vinyl-based" paint over a non-vinyl-based paint, but check the info on your new paint for any compatibility issues. The other potential issue would be if the old paint were one of the Teflon-based paints sometimes used in freshwater, but it doesn't sound like that is what the old paint was. Most recomend removing the old paint if it is flaking or of unknown type. In general though, a good thorough washing of the old paint surface to remove any dirt or scum/algea then thoroughly sanding with 80 grit paper and thoroughly wiping off the surface after, will be prep enough. I sand the bottom (after scraping any loose areas) of my boat (17' O'DAY) each year with a wallboard screen sanding pad, wipe it down with a rag, then apply the new paint (lately either Petit UnEpoxy or Interlux FG Bottomkote) with a small roller. Despite carefull scraping of loose areas (and checking for such areas over the whole bottom) I still get chips that flake off while I'm applying hte new coat of paint. One of these years I'll sand/scrape/remove all the old paint (last scraped bare in 1997) but I don't look forward to the mess!
Don't forget to paint as much of the retractable keel as you can get to, and under the trailer rollers/bunks. On our old CAL 21 we were not on a trailer, the boatyard had us on an A-frame roll-around cradle, so we could lower the keel enough to paint most of it and up into the keel trunk as well. On my DS II I am able to move the boat half-way off the trailer by supporting hte stern on a saw horse, so I can lower the CB about 2/3 and paint it and the trunk, as well as the areas normally blocked by the trailer bunks and rollers.
Also, check your boatyard, do they have any restrictions on sanding? Some places require that you use a sander hooked up to a "hepa" vacuum to collect the dust. Others may have special areas reserved for sanding, check before starting.
Mar 7, 2013
30
Thanks so much for the tips. I'll definitely hook the shop vac to the sander. I'm doing the work in my back yard. I will be blocking the boat up off of the trailer to make it a little easier to sand and paint. I have taken two power boats off their trailers before, but I'm gonna try to get this one up to 4' high to get access to the keel. Looks like this weekend will be a messy one.
Just make sure you are careful with blocking that boat up by yourself Slogfish. Feel free anytime to contact me as I was a dealer in that area for a long time and know about the smaller boats.
Jan 31, 2015
5
One other thing to consider - if the boat was always trailer launched your keel probably doesn't have a zinc. If it's made from steel (unless totally enclosed in fiberglass) and you plan to keep it in all season it would be a good idea to add one to prevent corrosion. A "disk" zinc should work well. It's work to drill a hole through the keel board to mount it the first time, but not too bad.
Mar 7, 2013
30
Yea I'm thinking it must've sat in some water at some point in a previous life, hence the old flaky bottom paint. The keel is cast iron and it does have some rust popping through the paint. Great idea with the zinc, never thought of that but I will do it. Thanks!
Feb 26, 2011
1,440
A zinc anode will do nothing to stop rust. In fact, on a pice of iron that big, most common anodes will be insufficient to protect against electrolytic or galvanic corrosion as well.
Mar 7, 2013
30
Hmm ok, Well i see you are a professional bottom cleaner. I guess you would know. I never thought the bottom of a boat would be so complicated. I just cant wait to get the bottom covered with water so I can play on the topside. But I'll try to lean over as much as I can to show off my new paint!
