Type of paint on bottom
You will have to find out what type of paint is on there now. There are two basic bottom paint types ablative and hard epoxy. Ablative is soft and sluff's off over time as you go through the water. Hard epoxy does not. You can apply some paints over others and some you cannot, that's why it is important to know what's on there now. The paint manifacutures, and marine store personnel would be able to help you decide what you can paint over and what you can't. Then you have to decide which type to use. The hardest part of painting is the bottom prep. If you have alot of old paint bulid up you will need to remove it using a small orbital sander with about 80 - 100 grit paper attached to a vaccum. Most yards will require this dustless approach. Take off the excess layers, check the bottom for blisters, and then put two coats on. The paint is expensive. Especially the multi-year variety. Also some paints require that you launch the boat within 30 days of application. Check this out before buying. I have gone with the ablative, they are less work, and create less build-up. Good luck.
