Mark Melchior
I have a year-old Catalina 250 that I keep on its trailer at the marina. The hull has gelcoat that looks like a mirror and I hate to bottom paint it, but my wife thinks she might enjoy the boat more if we wetslipped it. Our Texas lake is freshwater. Temps range from the high 50s during the late winter to almost 90 during the late summer. I've been told that warm water speeds the development of blisters.I'm thinking of using VC-17. Even if I allow the marina to do the work, I want to know the best method to prep & apply the bottom paint.What prep work needs to be done below the waterline? I know about acetone to remove the mold release wax. What else? Would a barrier coat void the Catalina warranty? David Graas at Catalina tells me that after the gelcoat is sprayed in the hull mold, a vinylester resin/chopped glass layer is applied as a barrier coat before the remaining fiberglass laminations. Is the "barrier coat" he refers to sufficient to prevent blisters?My boat is the water-ballast model and the centerboard trunk will need special attention.Your thoughts on VC17 in warm water or other recommendations would be greatly appreciated. I will occasionally pull the boat out of the water on my trailer for maintenance. I want a bottom paint that can take this type of "abuse".
