Unfortunately my first post was not articulate enough. I said the bottom was down to the bare fiberglass on my first post, my error. I should have said down to bare jell coat in spots
I dont know what bottom paint was used when the boat was new in 1975
but I do know it was a hard bottom paint. Again when I got the boat 9 years ago it had an old blue caked and chipped hard finish bottom paint on it. There was never any barrier coat applied to the bare bottom. When the boat was new the bottom was first painted with the hard bottom paint right on top of the jell coat When I first got the boat I sanded the old hard bottom paint smooth. The entire bottom was covered with this old blue hard paint. It was smooth with good adherence after sanding no bare spots. I would have had to strip the bottom to get the old paint off so I painted over the old blue paint with 2 coats of red ablative bottom paint. and have continued to do the same each spring for the last 8 years. When I had the bottom pressure washed each fall some of the red ablative paint came off, but the original blue hard finish paint always stayed in tact. This year was different. When the bottom was pressure washed several large sections of the old hard blue paint came off exposing the bare jell coat. My Question: for someone in the know. Can I sand the bare jell coat apply 2 coats of ablative directly on top of the bare spots or do I have to put some kind of protective coating on the bare jell coat before applying the ablative bottom paint. The bare spots are about 10% of the entire bottom
