Sorry, I did search for the answer .... If your boat has a barrier coat, no history of blisters, and CSC was installed every other year for a decade or more (the exception was ACT last June), and there appears to be a LOT of bottom paint still on the hull, is it necessary to continue to apply bottom paint each or ever other year? Meaning, if you see the ablative bottom paint, does it still retain 100% of its anti-fowling properties? Or do these properties diminish over time regardless if the paint remains (well, looks) intact. I am a believer in preventive maintenance. However, I don't want to overdue it. Similar to modern car running synthetic oil and the mfr recommends changing it every 7,500 miles. Your local Jiffy Lube says every 3,000 where oil samples and other supporting data says you are throwing $$ away inside of 15,000. So Interlux, boat yard, real world, respectively. What is the true story of ablative paints?
