Browndog68;
You mentioned bottom paint of one year only and want to pull it out to clean. You advised pulling it out. Not sure of other circumstances.
If you are in a warm area and going into the water is not an issue, then go swimming and take a sponge and a mop to clean the bottom off. Do not use a brush as it will take paint off. If you have zebra mussels or barnacles, then power wash at low pressure quickly before the hull dries with scraping using a paint scraper or somehting like that only. Placing the boat on the trailer will create a few issues as the centerboad is in the CB trunk housing and getting up there will be harder as you will have to crawl underneath and clean which can be messy if it gets on you.
There is a product that basically is a sponge which has some flotation and a long handle which will clean the hull of a boat. Not sure if it works that great but I do not know the name of it. Ok guys, do you know the name of this product?
When describing an issue, it would be more helpful where the location of the boat is and a little more detailed information would be very helpful when trying to respond would be greatly appreciated.
crazy dave condon
