Bottom of anchor locker disintegrated
tjf
Jun 8, 2005
6
Hunter 306 Crofton, MD
The bottom of the anchor locker in my Hunter 306 basically disintegrated and there's now a hole in the bottom of the anchor locker. I'm sorry I didn't take pictures but I can this weekend. Has anyone had this happen before? I think the bottom was wood but I can't check until this weekend.
tjf
Jun 8, 2005
6
Yeah, my post was pretty vague. We have someone coming to look at it this weekend and I'll be getting to the boat too. I'll try to take some pics and post some real info and pics.
Jan 4, 2006
7,870
Most Unusual ............................
..................... but we could philosophise how this occurred this until hell freezes over, the question is HOW TO REPAIR IT ?
My suggestion would be to clean out as much of the disintegrated plywood, fiberglass, etc. as possible. This is going to involve many hours of hanging upside down in the locker. You may also be able to attack this from inside the V berth by removing any covers in this area and going at it.
Next, I would suggest precisely fitting and inserting a piece of 3//4" plywood or thicker (stack and glue). The piece should fit in like a cork such that it wedges in place as the bottom of the locker is like an inverted pyramid. Once properly shaped, it should be liberally glued in place with with epoxy glue.
Next is to seal the whole plug with a layer of several inches of pour in epoxy. The attached manuals will steer you in the right direction for products. Any brand of epoxy (not just System Three) will do as long as they publish good .PDF manuals. Most manufacturers of epoxy products do.
This should be an inexpensive but labour intensive job. Welcome to the wonderful world of boating :cussing:.
