I have a '88 H28.5 with no epoxy barrier coat. It has3-4 coats of Micron CSC and it's getting chipped, worn and looks terrible. I've decided to bite the bullet and get down to bare hull, add 4-5 coats (8 - 10 mils) of epoxy barrier and then apply some VC 17 or 18 (Great Lakes).I've been told an easy way to get the bottom paint off is to have a pro come in and "soda blast" it off. Supposed to take the paint off, not hurt the gelcoat, and leave a clean, shiny hull ready for for barrier coat. Aynone used this method? Results?Recommendations on Barrier coat brand? I've heard Interlux is bad stuff. True?Also, What is the best way to coat under the cradle pads/yoke? Should I do everything but under the pads, leaving a roller-width, get all 4 coats on first and then move the pads and do those areas or ???I assume I can get 4 coats of epoxy on in a day or 2, let it dry a week, then put my VC 17 (quick dry) or VC18 (slower dry) on.Ay suggestions would be appreciated.
