Michael
This coming spring I would like to remove the bottom coat and repaint the boat below waterline. The conventional method of the old paint removal is sandblasting. I heard about an alternate method of bottom paint removal using high pressure water (1500 psi) spray with injection of abrasives such as soda powder. The injection proceeds through the ejector installed on the h. p. pump suction. Could anyone shed light on the issue? I would also appreciate references to literature, specifications and some assessment of both methods, one entailing required portable equipment used for sandblasting and the other method of high pressure water application.Many thanks,Michael.
