Hello to everyone. I have been reading this forum for a while since I am a new boat owner and I am making my dream come true. It is so many information on this forum that I got kind of confuse. I mean what the gelcoat exactly is? I know what it is for I just don’t know how it looks like. Can you please take a look at pic 1 and tell me if the gelcoat is the white stuff or the brown that is under the white.
I am restoring the bottom of 23 ft boat. The boat is from 1974 so I believe that gelcoat is made from epoxy resin and I am going to stay with product base on epoxy resin. The boat has 2 blisters. I opened them to dry. They are kind of big like a top of soda can [pic 1]. I am going to fix it with epoxy resin and some fiberglass. I also have some small holes and I believe that is osmosis. [pic 2 and 3] the boat was covered with kind of blue paint [pic4] I believe it was antifouling. I remove it with paper 80 and then 120 grids. Now, to fix the osmosis will be enough to put barrier coat paint on the white stuff I have on the boat? Should I remove the white material? The side of the boat above the water line is made from the same material pic 5. Should I cover that area with barrier coat as well?
I hope I did describe my questions clear and I am looking for any information.
