Bosuns Swing
1
- - Lake Champlain
Can we swing by the halyards in our Bosuns while underway on our Catalina 27
Apr 8, 2010
1,606
Frers 33 41426 Westport, CT
If you try it under sail, you might find your weight plus wind induced heel, enough to get yourself, and maybe even the top of the mast wet....
I wouldn't do it on a boat that size. 15k lb displacement boat maybe...
Catalina 320 Dana Point
As a general rule of thumb: If the boat don't move when you walk from rail to rail at the beam, swing away.
jrowan
Mar 5, 2011
1,294
Take a look at all the rigging up there & then predict how hard it will hurt when your head, etc. hits the end of the spreaders or you get whipped in the neck by a shroud.
But by all means swing away, and then Post a vid on You Tube on "How to get busted up on a sailboat." lol.
