Boom Vang Recommendations?
Steve Linsk
I am planning to retrofit my '86 Cat 30 SR with a rigid boom vang. Can anyone recommend a good quality kit/manufacturer for one of these? I've heard Garhauer makes a decent one.
Ron
aaaarigid Boom Vang
I installed the Garhauer solid vang on my 1987 30TR and am very pleased with the result. The price was very reasonable considering the quality of the vang and it even came with line.
C
Chris Gonzales
Garhauer...
Steve, I bought a Garhauer rigid vang for my C25 a couple of years back. It was a pretty simple design, basically two tubes with a spring inside, but considering the price and quality it was fine. Installation was easy, too. I am probably going to order one for my C30 soon. Chris
G
Geoffrey Jackson
Garhauer vang from Catalina Direct
I recently installed the Garhauer rigid boom vang on our Catalina 27. I ordered it from Catalina Direct. All things considered, the price is right. Very solid unit. There are some great advantages to the rigid vang when sailing shorthanded. Ease of raising
G
Geoffrey Jackson
Garhauer vang from Catalina Direct (version 2)
Apologies for posting this twice. I edited the original after posting and the system truncated the article. This is the complete diatribe. I recently installed the Garhauer rigid boom vang on our Catalina 27. I ordered it from Catalina Direct. All things considered, the price is right. Very solid unit. There are some great advantages to the rigid vang when sailing shorthanded. Ease of raising & lowering the main, reefing. Some considerations - - You will need some type of cleat installed to control the vang. - You will probably want to run the control line back to the cockpit through a deck organizer. - Your boat may already have the hardware installed. If not, you'll need to add it before you can make use of the rigid vang. - The gooseneck should be locked in place on the mast. Obviously, you need to be able to completely raise the main, so mark the desired position when the sail is up. - The recommended installation for a boom vang is at a 45 degree angle to the boom. You must make sure that you can pull the boom down enough to get the desired sail shape with the vang installed. Depending on how things are set up on your boat, you might need to move the bracket that attaches to the boom farther aft than the ideal 45 degree angle would dictate. Check this before drilling and tapping. My unit required some reshaping of the bracket that attaches to the boom. The curve was a bit too wide. I checked with the C-D tech support guy, who said to hammer on the thing with a two-pound hammer until it fit correctly. After working on it rather timidly for about 1/2 hour, I started really pounding on it with a large decking hammer - less than 2 lb, probably about 12 oz. but the largest hammer I own. Took another hour of pounding and checking the fit to get it snug. I figure that it's probably the solidest part of the boat. Regards, Geoffrey Jackson
Bob Camarena
Order from Garhauer
Personally I'd cut out the middle man and order direct from Garhauer. I haven't checked prices, but I doubt you save anything by going through Catalina Direct. I have nothing against them, but Garhauer is great to work with, will consult over the phone and knows their product.
