Boom vang position
7
- - Port Jefferson
I have a 2004 Hunter 41 with in mast furling. I have found that the boom vang in its current position (from the manufacturer) is of limited value. It is unable to extend when released and the boom moves minimally and remains in an elevated position when the vang is tightened. Any thoughts or experience from anyone about moving the boom vang positon or any other interventions in order to maximize the usefulness of the boom vang?
Alan
Jun 2, 2004
4,174
Hunter 35.5 LI, NY
If you disconnect the (I assume solid) vang from the boom with the main raised, can the boom be drawn down well below the horizontal? Under normal circumstances, when the vang is applied with suffient force, it should be able to bow the boom slightly.
Mulf
Dec 2, 2003
400
Hunter 410 Chester, MD (Kent Island)
I have a 2002 H410 and spoke to Selden...
because the rubber collar at the top had spread around the top fitting and was wedged in such that it pulled out of the main vang tube. He said that the vang was incorrectly attached to the boom to do this as it was never meant to support the boom (unless you have the gas cartridge added). They were very helpful, sent me the replacement collar for free on the condition that I would change the boom connection position from what the dealer had installed. What I was told to do was, in slack wind, to release the vang, remove the screws holding it in the boom track so it would slide freely, pull the main all the way out, and then tighten the mainsheet fully taught. He also said to tighten the topping lift to this same setting. This puts the boom at a maximum low point. Note that the screws only hold the slider from sliding and do not need to be tapped, only drilled enough for the bolt to pass through. The next step was to mark the place on the boom where the vang fitting would still leave the vang about an inch above the collar. Then redrill so the bolts will hold the vang slider at this point. No problems since doing that. If you do not have a Selden vang you might want to call the company for your vang to verify proper installation position.
Jan 9, 2005
7
- - Port Jefferson
Thanks
This seems to be exactly my problem including the broken rubber collar. My only issue is that the arch will prevent me from moving the boom vang too far back. Thanks for your help. I will be contacting Selden for their assistance.
Jan 9, 2005
7
- - Port Jefferson
The boom doesn't move very much
There was no significant movement of the boom when I tightened up the boom vang.
Alan
Jun 2, 2004
4,174
Hunter 35.5 LI, NY
Then the vang is of no real value! If the boom can't move verticlaly then you loose yet another sail control, twist. This is a crucial element of sail trim.
