Does the rigid boom vang require drilling the mast? If so how about using the track to attach a non- rigid vang? Does it require drilling as well? Is the rigid vang worth the trouble?
yesDoes the rigid boom vang require drilling the mast?
yes, yes. you may be able to fit a padeye in the mast groove, slide it all the way to the bottom, a self tapping screw just above it will keep it from sliding upwards. Are you afraid to drill a hole in your aluminum mast?... You'll get over it.If so how about using the track to attach a non- rigid vang? and Does it require drilling as well?
Absolutely... if you purchase the Garhauer vang, they will include custom brackets for mast and boom with instructions on where and how to install. The greatest advantage of the rigid vang is the positive control on the boom, up or down, the device offers. No more topping lift, you can have as much roach on your main or a full set of battens and never deal with the annoying hang ups the top lift causes.Is the rigid vang worth the trouble?
Thank you very much.Everyone seems to sing the praises of the rigid boom vang. However, I am a little skittish about drilling my mast. For a rigid boom Vang to work can the bottom connection to the mast rotate or does it need to be stable. If it needs to be stable than it seems like you would have to forget using the track and attach a bail through the mast. Clearly, I would prefer to use the track if it still works under the circumstances. One drill hole must be better than two.
