Jerry,I sometimes run a line from the boom bail to the base of a stanchion to prevent accidental jibes. I have used the vang for the same purpose, but its usually more work.
We usually just rig a preventer with using extra line attached to the eye where the clew reefing point is on the boom. I think it would probably suit you better to have a preventer attached to the boom a little farther aft then the vang. Having it so far forward may exert too much pressure on your stanchions.
I agree that there would be less stress on the stanchion if the preventor was rigged futher aft on the boom. I was thinking of using a sliding bail origionally intended for reefing as an attachment after fixing it by the companionway. I would also use it for the mailsail sheet to get it out of the way.
