My O'day 25 has a boom track that gives it about 8" or so of movement up and down on the mast.
When I got the boat there were screw stops at the bottom and at the top of the track. I didn't think the boom needed that much travel so I put a stop so it sat about 3" below the black stripe on the mast. I have a line tied to a hoop on the bottom of the slide that goes down to a cleat on the mast.
I have the line cleated to allow the boom to slide up the track to about mid black stripe. That is the black line in the photo. Ignore the other lines as several shown were testing angles for mounting the hardware to run back to the cockpit.
When I raise the main, the boom does not slide easily up the track. Sometimes it will move up while I tighten the halyard and other times it doesn't until I start sailing and then I will notice it slid up and the downhaul line is now tight. I then point into the wind and re-tension the halyard.
Even spraying it with McLube doesn't help it to slide easily, even if I am manually pulling it up.
I am thinking I should just cleat off the line so the boom is tight against the stop so I can set the initial halyard tension and it won't change. I moved the halyard and reef lines to the cockpit so I don't have to go to the mast to set the main so I don't plan to adjust this boom downhaul when I am sailing.
Am I missing something? Sounds too simple.
