Boom mounted hammock?
I've seen it done but I'm a big guy so I have not tried it. Is there enough distance from your mast to the forestay to keep your arse off the deck........inquiring minds want to know....
May 20, 2016
3,015
I’d be afraid of bending the boom before breaking the forstay. If your worried about the stay - rig a halyard to the tack for extra support.
Likes: tfox2069
Oct 29, 2016
1,929
Hunter 41 DS Port Huron
@Project_Mayhem 1/4" Cable has a breaking strength of about 7000# I think you will be fine. Rig one end to the mast and the other to the topping lift, the outboard end would only be carrying 1/2 the load.
Jan 5, 2017
2,485
We used the boom to lift a 480# Perkins 4-108 out of a Fast Passage 39, and to put it back in. Did tie the main halyard to the boom end though.
Oct 2, 2008
3,811
Pearson/ 530 Strafford, NH
???? where is the fair maiden with your drink????
That’s a good question!.! Where’s my drink woman?
Spinaker halyard and a little loop around the staysail furler.
I’ve seen hammocks done from headsail furler to the mast.
Likes: tfox2069
Nov 8, 2010
11,386
This works if you have enough distance. Forget about the boom. Use a spin halyard to keep the forward loop at the right height on the forestay . Use the main halyard to keep the aft loop from slipping down the mast.
Likes: All U Get
