I'm looking for a couple of things I hope the community can help with. Lines from my mast run under a couple of panels on the deck to clutches at the cockpit. After the lines run through turning blocks at the base of the mast they go under a metal bar that has serveral nylon rollers that spin as the line runs against them. These keep the lines low and set them up to go into deck blocks. What I need is replacements for these nylon rollers. Some of mine have deep grooves and don't spin under load, adding considerable friction.
Also....I'm looking for a source for roller bearing sheaves to replace/upgrade the ones in the ends of my Selden boom?
Anyone got any ideas/sources?
-charlie
-charlie
