Hi All,
I could use some guidance, direction, advise on my topping lift and my boom.
On my old Cal 21 I attached the boom to a small wire attached to the back stay. This kept the boom up and centered on the boat when not in use.
On Take Two I have a topping lift cable with a block attached. Do you all have this set up? How do you rig it? How do you keep the boom centered if you want to disconnect the main sheet at dock?
As you see in the first picture, I have it jury rigged for now.
Also the boom has at the aft section a block on the port side, a cleat on the starboard side and Stainless-Steel Eye Straps on both side but in different locations. What is all this hardware for?
The boom on the mast side has an internal system where lines come out which I believe is the outhaul.. Correct?
Any pictures with your feedback would be greatly appreciated.
Thanks,
Chris
Thanks,
Chris
