Hi Charles, I will check my shop manual. I know some engines like Yanmar had pencil type anodes but I haven't found any reference to this with Volvo.OK
The fact you have a motor/saildrive propulsion changes things -- always a risk of long distance diagnosis.
Bonding the other underwater metals to the motor/saildrive will lead to accelerated wasting of the saildrive anode because the anode will be protecting the saildrive and the other underwater metals in addition. Volvo did not intend that the sail drive anode should be protecting anything except saildrive. But they claim the drive is electrically isolated from the motor.
Check any motor/drive manual to verify whether the manufacturer permits bonding of other metals to the motor bock/saildrive and if so then whether additional anodes are recommended.
Be certain to keep the saildrive anode fresh, clean, and working.
As to the paint - two questions: what is the hull made of and did the paint fall off altogether or is there still paint under the effected area ?
Charles
I do watch my anode carefully. Our season is about 4 months long so usually (so far) 1 anode is consumed per season. I change it annually before launch.
The hull is fiberglass. And it did appear the paint was gone. I think what is left is barrier coat and maybe paint remnants. The through hulls are marine grade bronze. The brand escapes me but it was one of my first stops looking at the boat. My first guess is Conbraco but I'd need to double check that. I haven't been on my boat in months.
SC
