Boating regulations?
jviss
Feb 5, 2004
7,089
Tartan 3800 20 Westport, MA
I am suddenly having a senior moment (although I'm not a senior yet); can someone please pint me to the boating regulations for Massachusetts waters, and coastal waters? A friend just bought a Boston Whaler 13, and we were arguing, um, discussing the minimum equipment requirements for motor boats. I was wrong about the fire extinguisher. I thought it was required, but for MA it isn't: "Outboard motorboats less than twenty-six feet in length of open construction, not carrying passengers for hire, are not required to carry fire extinguishers." Per MGL 90b-5 So, what about the anchor, paddle, PFD's, lights - what are the real, hard rules which if you break you could get a ticket for, for both MA waters and coastal waters? I searched the web a bit but can't find anything definitive in one place. Thanks, jv
3,503
Everything You Need to Know, Almost
There may be additiional requirements for the State getting with the Coast Guard Auxiliary or the Power Squadron in your area will get you the answers for that. Lights, PFDs, and some sort of visual distress signal (flares) for coastal operation are required the paddle and anchor are not.
jviss
Feb 5, 2004
7,089
Thanks, but...
were you thinking of a specific page on their web site? I can't find a "regs" page.
jviss
Feb 5, 2004
7,089
Rick,
thanks, but I've found that that's not correct, apparently a paddle is required on boats less than 16', and an anchor is required: "Additionally, the state requires that all motorboats (with the exception of personal watercraft) be equipped with an anchor, manual bailer, and line. A paddle or an oar is now required only on boats less than 16 feet in length. " from: http://www.mass.gov/dfwele/dle/boatinglawsummary.htm Where did you get your information? jv
3,503
Navigation Lights
Reading the link I provided may lead you to beleive that on a thirteen foot boat you do not need the red, green and all around white light. There is an additional portion to that rule that states if the boat is capable of more than six knots it must have the red, green, white lights.
Ross
Jun 15, 2004
14,693
This really comes down to ; How well
do you want to be seen and how long can you tread water. Big brother is there to watch out for fools and small children when god is busy else where.
3,503
Sounds Like You Have your Answer
The link below will take you to a virtual Vessel Safety Check. The specific requirements for the paddle and anchor are for the state the link I posted gives the US Coast Guard requirements. As I mentioned the state may add requirements that is why I suggested getting with the Power Squadron or Coast Guard Auxiliary for additional state requirements.
Sunshine
No Fire Extinguisher?
You trying to tell me that 25 ft sailboat powered by an outboard does not have to have a fire extinguisher. Try telling it to the Coasties when they perform a safety inspection. The pecking order will be quickly displayed.
Ross
Jun 15, 2004
14,693
Sunshine, I said in another post that big
brother has to look out for those that don't have good self preservation instincts. No fire extingisher? fine! Cleanse the gene pool.
3,503
Read Closer Sunshine
Fire extinguishers are required if one of the following conditions exists: (1) Inboard engine(s); (2) Closed compartments that store portable fuel tanks; (3) Double bottom hulls not completely sealed or not completely filled with flotation materials (4) Closed living space (5) Closed stowage compartments that contain flammable materials or (6) Permanently installed fuel tanks NOTE: Fire extinguishers must be readily accessible and verified as serviceable.
May 21, 2004
36
Sabre Sabre 32 Salem
Here are the MA regs
http://boat-ed.com/ma/handbook/ I'd recommend a US PowerSquadron or USCG Aux class.
jviss
Feb 5, 2004
7,089
Coast Gaurd Aux. class?
Thanks for the link, and the recommendation, but I'm not looking to take a class, I'm only interested in finding the regs to refresh my knowledge. Sunshine, I'm not trying to tell you anything, I just quoted the Massachusetts General Law. If you read it carefully you would note that it refers to "open construction," i.e., no cabin or other enclosed structure; think of a big canoe with a sail and an outboard. Meanwhile I found the text of the actual regs, which I think are easier to read and digest than MA's web based drop-down menu version: http://www.mass.gov/dfwele/dle/323cmr.htm linked from: http://www.mass.gov/dfwele/dle/boatrvsafe.htm
