I have some 3/0 wire with hydraulic pressed lugs that I would like to use.
Here are the markings from the wire.
3/0AWG (85mm2) E125352-U (UL) BC-SW2 or MTW or THHW FOR CT USE OR AWM 1232/1284/1338 600V OR 10269 1000V OIL RES | SUN RES VW - 1 - - 156016 CSA TEW 105C 600V FT1 OR AWM I A/B 105C 600V FTW W75 0 - -SAE J1127 TYPE SGT
Quite a lot of stuff there, no idea what it all means. Is this sufficient for marine use? The lugs are open ended with plastic insulation around them. I could put the heat shrink with the glue to keep corrosion to a minimum. Any thoughts or ideas?
