Boat Speed with the Yanmar 3GM30F
John
Checked with Yanmar
I certainly recieved a lot of advice on my question, but would like to clarify a few points. I checked with a a Yanmar service rep and it does more harm to the engine to run it at 2000 rpm or less than it does to run it at 3000 rpm. According the representative I can expect to get thousands of hours of good service from my engine running it like I do. However, for those of you that idle around continuously, you may be in for a suprise. Talk to your Yanmar rep. Second, I fully understand that the engine on a sailboat is a secondary source of power. Frankly, I thought that was a petty and condesending comment for anyone offering advice to make. When I can sail I do. Most of the comments I got about not worrying about speed etc. came from folks on the East coast. Obviously, you have never sailed in the inland waters of Puget Sound. Tide shifts here can be up to 18 feet between high and low tide creating terrific tide rips and currents. And, more often than I like, there is little or no wind to sail with. In some areas the currents nearly match hull spead and the tide rips create huge waves. Do you have any idea what it is like to be caught in a situation like that and not have your engine performing at its best? When the wind is not blowing would you suggest leaving the boat in the slip? For those of you that made suggestions on how to achieve max performance - thank you. For the rest- perhaps you should consider being less judgemental and more helpful. John
Marcus
Excellent perspective!
Your post resonates. Each of us is totally wrapped up in our own unique "sailing universe". How difficult it is to picture accurately what is being described by others. I wish us all the best of luck in whatever sailing endeavor we undertake-it's never easy, but always satisfing. Remember why you come here-you are a sailor.
Mark MIllham
Sorry if you were offended
Sorry if we offended you. I beleive everyone who responds on this site is truly trying to help, not to be condescending in any way. Myself included. Please pass along the details of the info you received from Yanmar. I am interested to hear what he had to say. If you could supply aphone number, I would liek to talk to him myself. None of us want to damage our engines. You and Marcus also bring up an excellent point. There are significant differences in east and west cost sailors, and I certainly have not had the pleasure of sailing on the west coast.....yet When I post questions here, I take what I think works for me, disregard the rest, but am thankful that there are many others who will take the time to try and help. As far as performance on my 356, I get 5-5.5 knots at apx 2500 - 3000 RPM depending on seas. I will verify this once I get out to sail this summer, my memory is sometimes shaky. I do have the 3 bladed prop, which I highly recomend. Take care:)
P
Pete
Yanmar curise RPM's
John, I think there is a consense of opinion that the 2500 to 3000 rpm range is best for long term operation.running slower rpm's has a frequent side affect fo clogging the exhaust elbow prematurely. Check the link to Yanmar help below. It is not the factory site but run by a fellow who is very very "Yanmar Smart" I think he (check his info) ran a big Yanmar shop overseas.Lots of good info and a guestion board. Good Luck !
Rick D
Jun 14, 2008
7,182
Yanmar RPM
I've attended several Yanmar Distributor seminars. The Yanmar engines live longest under load, 80% of maximum RPM. Check your manual. Also, Don't motorsail for long periods with little push from the engine. Remember, it wants to be loaded. After running the engine to charge batteries (2K RPM) run the engine full throttle for about five minutes to discharge the carbon before raising sails. Likewise, let the engine run at low RPM (1K) for about five minutes before shutting it off after running at cruise RPM to avoid hot spots. Avoid over-propping. The engine should turn full one-hour rated RPM under full throttle. Don't let the engine run long periods at idle. Throttle up to 1K RPM to keep oil pressure up. Don't wait to warm it up in the slip. Just a couple of minutes to get the oil well-circulated, then under modest RPM as you motor through the harbor so that it is under load. Did I say it wants to be loaded up? Good luck. Rick D.
Dec 2, 1999
15,184
Yanmar Help!
http://www.yanmarhelp.com/ Some good tips, it you have not reviewed this site before.
Miguel Gonzalez del Rey
speed checked
I cheked my speed last sunday with flat seas 6 knts at 3000rpm average st40 and gps 6.5 at 3200rpm I have a 3 blade prop Miguel h356 #255
