i have a capri 26 with an universal m2-12 engine. cruising speed is supposed to be between 2700 to 3300 rpm. when i get around 2900 rpm. the boat begins to shake and i can 't go any faster . hull speed is supposed to be 6.4 kn. and i can hardly get to 5.7. Could it be the prop or the shaft alignment. how to know which is wrong . Since the boat is still in the water i can' t any detail on my prop specs. at lower speed ( 2500 rpm ) and lower it works fine
