Boat lights
15,184
Costco had 110v ones for xmas.
Wright: Costco had them for xmas. They were 110VAC. The good thing about them was that they were LED lights. So all you needed was a small inverter.
Benny
Inverter
Steve is correct the way to go is an inverter. A 400 Watts will do for a few strands of the small bulbs. There are 12V out there on the market but I have only seen them on flea markets and the quality is very poor. A direct connection of the inverter to the battery (no cigarrete lighter plug) will allow the use of more lights.
Dec 2, 1999
15,184
A lot smaller than that for LED.
Benny: One of our fellow Hunter owners using a 75w inverter with a couple of hundred feet of LED lights for a parade. If you use traditional light bulbs you would need a much larger one as you mention.
Jan 2, 2005
779
Hunter 35.5 Legend Lake Travis-Austin,TX
Check out...
www.sailorsam.com for 12 volt, LED "rope lights".
