Boat and trailer
Aug 26, 2019
59
Hunter 260 Eau Claire
Does anybody know if a Hunter 260 can sit on the trailer without the centerboard ? I want to refurbish my centerboard over the winter. There is weight that the centerboard supports and was wondering if, without the centerboard, there will be too much weight on the bunks alone ?
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
Not according to post #2 and others in this tread on the same subject.
-na -NA Anywhere USA
In a week send a private message as there should be freedom of movement while boat on trailer. You need to raise the bunk boards
Will discuss with you. Hopefully others will chime in.
Jan 3, 2022
14
Hunter 19-2 Sevilla (Nautic Club)
Hello, I´ve a Hunter 19-2 in Spain.
I want buy a trailer and I need to Know the weight in Kg out of de sea (not displacement)
Anyone cab help me?
Thanks
Aug 12, 2018
163
Hunter 26 Carter Lake, Colorado
According to SailboatData.com the trailering weight of the 19-2 is 1500 lbs/680 kg. It is a water ballast boat.
My info came from the top post I went back and whoever posted it, put the 23.5 info in. The full manual verifies @twistedskipper put in. My apology
always verify the info to the boat in the side boat picture
I was involved in the design, introducing and ending production. That is why I went back to check. It was my design of the 23.5 and should have caught myself when I first looked
@Phil Herring
Under Hunter boat information for 19-2 for 1993-1996 under downloads, can you remove the first manual that is the smallest as it relates to the 23.5?
it is confusing and I did not catch it at first.
