P42 can cruise
If given a choice between a new Hans Christian Offshore Explorer 4750 and a Hunter Passage 42 for cruising, who wouldn't take the Hans Christian? However, money is a factor (at least for my wife and I), and we would rather be out there cruising than sitting in Anchorage working for enough to buy a better boat. Hence the P42.The P42 is not a bad cruising boat. We've done extensive cruising in our 1990 P42 (hull #65). We've lived in it for 5 years, most of it cruising. We've put on about 25,000 miles and sailed from California along Mexico, to the Marquesas, Tuamotus, Society Islands, Cook Islands, Samoas, Tonga, Fiji, New Zealand, Wallis, and beat to windward from New Zealand to Fiji to Wallis to Western Samoa to Penrhyn (Cook Islands) to Hawaii to Los Angeles. One passage was 28 days, another 21 days, and a bunch were in the 5 to 10 day range. I feel like we know the P42 pretty well.Phil's points are all well taken. Sea berths can be a problem. My wife and I double hand, so we don't have a problem. The aft bunk is large enough that a single person can lay across it in any direction, and you can get a good sleep on either tack. It is very comfortable in a pitching sea. However, if you have a crew member, that person may find the forepeak a bit bumpy and noisy. If you're on a starboard tack, the port settee makes an excellent bunk underway. A bit more uncomfortable on a port tack, but our crewmember didn't seem to mind on the 28 day passage from Puerto Vallarta to Nuku Hiva. On the trip from Hawaii to California we had one crewmember in the forepeak, and another (72 year old) crewmember on the settee. They fared fine.The fuel tankage, at only 70 gallons, is a concern. We carried 7 five gallon jerry cans of diesel lashed to the lifelines on the longer passages. We also practiced fuel conservation by motoring at only 1500 RPM to extend our range, and would not motor until we got below 2 knots under sail. Ironically, we never entered a port with less than 70 gallons of fuel. However, the extra fuel provided the safety factor one needs on a long passage. One option available to a cruiser is to convert the (35 gallon) holding tank into an auxiliary fuel tank. It is easily accessible under the floorboards, and diesel can be pumped out manually, and then one can pour the fuel into the main tank by using the deck fill. This tank also is located close to the center of gravity of the boat. This requires extensive cleaning (or replacement) of the holding tank, but that is not a problem. We just had to replace ours (since Hunter commissioned our boat with bronze fittings in the aluminum tank, electrolysis corroded the tank, and we replaced it with a stainless tank). It was an easy and relatively inexpensive replacement.The water tankage is more than adequate. The aft water tank is ideal for filling with rainwater while at anchor. You simply need to place a towel in position aft of the deck fill to "dam" the water after letting the rain rinse the deck for a couple of minutes. The flow of water aft fills the tank rapidly. While cruising, we keep the aft tank full for a safety tank of water. (The center of gravity is better than filling the forward tank). We then keep only about 10 gallons in the forward tank as we use our watermaker under way (or when cruising in the islands).Power consumption is always a concern. We have 3 8G8D batteries (a third gel cell battery fits perfectly under the aft bunk just forward of the steering quadrant), and a 130 amp output alternator (with appropriate voltage regulator). We also use a Fourwinds water tow generator under way, and have an additional Fourwinds high output wind generator. We only use our freezer for food/ice, and use the reefer for ambient storage. If we find ourselves at anchor without any wind, we end up running the motor for about 1 to 1-1/2 hours per day. That generates our daily consumption of about 100 amp hours per day. More often than not, however, the wind helps us out. While passaging we have often sailed for up to a week without running the engine at all, relying completely on the water tow and wind generators. (We usually run the engine, when needed, to keep the batteries between 65% and 80% of capacity).The anchoring system on the P42 sucks. That's all I can say about that. If anything ever convinces me to deplete my cruising kitty by buying a different boat, that will be it.The boat displaces 24,000 pounds, and is therefore heavier than the 420. We added an inner forestay and storm staysail to ours. I also installed a trysail track, and had a storm trysail made. We also have an 18 foot diameter Paratech parachute sea anchor with its own dedicated rode. We have sailed in steady winds up to 45 knots, gusting 50. We have sailed in 25 foot seas. We have been in winds that did not drop below 40 knots for periods of over 4 days. I think the boat handles great. We usually are careful about maintaining the proper amount of sail for the conditions, and have sailed under all combinations using our sails. We also layed to our sea anchor for a three day period when we considered the weather so bad it was borderline to us to continue under sail. Never have I felt the P42 was anything other than stable. And we beat to windward from New Zealand to Hawaii to California.The P42 also will heave-to beautifully. We furl the jib (we replaced the continuous loop Hood system with an above-deck Harken), raise the storm staysail, and sometimes use a double reefed main for stability. We have done this many times, and she rides great. We only went to the storm anchor that one time because the waves were so high that we would lose direction when we were in the troughs, and it was too uncomfortable.I really like the P42. My wife and I are refitting ours now for another extended cruise commencing this October or so. We plan to go for at least five years this time. I am such a safety nut that I would bite the bullet and buy a new boat if I really thought we were endangering ourselves on the P42.I think you'll find the P42 a very comfortable and safe cruising boat. If you want to talk about modifications we've made, or other experiences we've had with it, feel free to email me at "paulcossman@hotmail.com"
