That's what I thought and have read. I was surprised to here so many say a C22 was safe for blue water. Thanks for your 2 cents.jrowan said:I'm kinda surprised that a prudent sailor would ever recommend to a newby sailor that it was a good choice, or even plausible to recommend a Capri 17 or C 22 as a blue water capable boat. These boats are the antithesis of what a blue water boat stands for. Blue water stands for an ultra stout, seaworthy and sea kindly design and construction build quality, which is not what the C 18 or C 22 would ever be referred to be. They are really just daysailers, or occasional overnighters, or pocket cruisers at best. I thinks it's downright irresponsible to promote a boat as flimsy as these to be capable of something that they were never designed to do. I say this as a former owner of an O'Day 19, a C 22 a C 25, a S-2 28' & O'Day 35, amongst others. Just because U can do something silly, soesn't mean U should. People have also survived going over Niagra falls in a barrel, but that's not what anyone in their right mind would want to do. Life is too short to be tortured in big seas in a dinghy. Coming from a backgrounnd sailing in the Irish Sea, England's North Sea, Eastern Canada & the Atlantic, etc. its foolhearty to take a boat of less than 25 feet & insufficient ballast & keel weight into the Blue water Ocean & not invite disaster. There are a very few stout boat designs under 30 feet considered worthy of Blue Water capable, such as the Flicka, North Sea, BaBa, etc. & they are a breed apart in high quality and weatherly build. When U sail in waves that are taller then your mast height in a gale force not of your choosing, then you'd wish you were not in a Capri! Just my 2 cents.
I'm looking for a rig that can handle it all, rough seas, high winds, ice. If you were go around the world, what would you pick I guess is what I'm asking.Ray Bowles said:jho, Sometimes a "blue water boat" is confused with a coastal cruising boat.
Walk the docks at any marina that could reasonably expect to have transient sailboats passing through moored there or visit harbours like Marathon Florida where these boats congregate before sailing to the Bahamas and points further east.
What you will see are many true blue water boats. They will mostly run between 30 and 50 feet with most being in the range of 35 to 48 feet. And yes, there will sometimes be a C22. He won't be leading the pack on the crossing, nor will he keep up with the pack. What you will see in all the boats is usually a captain and crew with enough confidence to make their voyage. Something else you will see is that most of the boats are well kept, properly rigged and carrying way more than just required safety gear. You might even see a boat that would do her owner a favor if she simply sank right there where no would be endangered rescueing her crew.
A coastal cruiser is a boat that most of us sail while learning enough, to become good enough, to try being a blue water cruiser. My wife and I went from a Hunter 260 that taught us to sail to an Island Packet 38 that we lived on and blue water sailed. We looked at 4 to 6 boats a day for more that a month solid before we found our boat. If you have seen the difference between a H260 and an IP38 there is no doubt that one will go anywhere in confidence and the other might, but it wouldn't be hauling my butt while it did. The H260 is a wonderful boat but it lacks blue water "stout". The IP is stout. A C30 is stronger than the 260 and works well as a coastal cruiser and I would be willing to take a properly rigged and equiped C30 anywhere 60 to 100 miles offshore. To sail to Australia or England I still would fall back to "stout".
Hope this helps.
Ray
