Rick S.
Where is the blue bungee cord at the centerboard supposed to be fastened? My 170, as it came from the dealer, had one end clipped to the centerboard bail and the other to a shackle on the mast tabernacle. Helps with the uphaul, I suppose, but does nothing to keep the board down, as some posts in the archive have suggested it is designed to do.I'm considering switching to end-boom sheeting, as Mike G. has done (see his post in the archives), to reduce the physical exertion needed to control the main sheet. Would probably use a 3:1 purchase, since end-boom sheeting requires less leverage but a longer mainsheet. Has anyone tried adding a block to the existing 4:1 midboom setup to make it a 5:1? Is this practical? I figure if I switch the two stock fiddle blocks so that the end of the mainsheet is tied to the becket on the upper fiddle block, I can add a large single block below the lower fiddle to make the final 90 degree turn to the cam cleat. Any comments would be appreciated.
