Blower with diesel ?
52
Hunter 27 MD
Newbie. 1982 Hunter 27, stock best I can tell, Yanmar diesel.
Is there a blower in engine compartment ? Required ?
I don't think there is one and I don't think there is one required for diesel powered boats - correct ?
Jun 7, 2007
515
Hunter 320 Williamsburg
No blower required
Blowers are required for gasoline engines because the fumes sink into the bilge and are potentially lethal. Diesel has a much higher threshold for ignition, compared to -45 degrees for gasoline. You're fine.
Sep 25, 2008
7,755
Alden 50 Sarasota, Florida
Engine compartment ventilation with a diesel is not essential but is useful only to cool the compartment.
Dec 19, 2006
5,836
Hunter 36 Punta Gorda
Blowers
A blower is not needed for Diesels and I have had 2 Hunters with factory installed blowers and I do use them only to help exhaust the heat from the engine compartment.
Nick
May 16, 2007
1,509
Boatless ! 26 Ottawa, Ontario
Mine came with a factory exhaust blower (orange hose), I think to get rid of excess engine heat, also a they included a fresh air engine intake (grey hose) because of an engine fire suppression system. It works well to keep the boat cool after a day of motoring.
A few hundred pounds of cast iron radiating heat for a couple of hours after you set the anchor can warm up the cabin in a tropical setting.......
Bob
