Bloody Dacron
309
Prindle 18, beach catamaran Chicago (North Edgebrook), IL
I really gashed my finger today on the boat, and unfortunately stained my mainsail.
What's the best way to remove the nastiness, or do I just declare it a badge of honor?
BobM
Jun 10, 2004
3,269
S2 9.2A Winthrop, MA
Found this on a site about ultralights
Dacron® Sailcloth - Mildew/Blood Removal: Remove both blood and mildew by brushing the stained area with a stiff dry brush. Soak the remaining stain (stained area only) in a mild fresh water and bleach solution for 1-2 hours, lightly scrubbing the spot occasionally. Rinse liberally with fresh cool water. Remember that mildew is a fungus growth and you should stop the growth and clean the affected area immediately upon noticing it. Since preventing mildew is much easier than removing it, please follow proper storage recommendations.
Ross
Jun 15, 2004
14,693
Try drug store peroxide first. Then use bissel carpet cleaner.
It works on light colored carpets in houses where the kids have come in and bleed on the floor before they could be hustled into the kitchen.
Ross
Jun 15, 2004
14,693
Won't hurt polyester. Any form of bleach on cotton is damaging
just spill chlorine bleach on a pair of jeans.
RichH
Feb 14, 2005
4,773
Oxalic acid
The stain comes from the hemoglobin (iron) in the blood. Oxalic will dissolve the iron (instantly); nothing beats oxalic for dissolving 'iron' stains.
Rinse well when done.
May 15, 2007
2
- - Texas
Milk
Soak it in milk and then rinse out. I can't remember where I read that but I used it once to clean a blood stain out of carpet.
May 11, 2005
3,431
Seidelman S37 Slidell, La.
Maic Eraser
Not sure about the sail, but couple of years ago when I came down off the mast in a big hurry, I bled all over the port side of my boat. It sat there for almost two months before I was up and around enough to take care of it. A magic eraser made it seem like childs play to get off. Literally just wiped it off.
Timo42
Mar 26, 2007
1,042
Venture 22 Marina del Rey
Leave it,
Think of the stories you can tell about how it got there. Here's a start "It was a dark and stormy night" you can take it from there. ;D Tim
