Block in Lazarette
May 10, 2019
6
Columbia 36 Severna Park
On a separate note:
Any advice for removing siezed seacocks? About to use my hitting wrench
Hunter 34 Herrington South, MD
One of mine froze and I broke off the handle. Just had it replaced during bottom painting.
Apr 8, 2011
774
Hunter 40 Deale, MD
On a separate note:
Just unfroze one a few months ago. It was below the waterline, so after some relatively gentle tapping didn't move it i waited until the boat came out of the water for the winter. Then I sprayed PB B'laster into the thru hull from the outside, and onto it where it sat in the hull and let it sit for a few hours. The handle then turned with more gentle tapping from a hammer, and now is as workable as all the others. Fairly certain what did it was spraying the penetrating solution up into the thru hull from the outside.
May 10, 2019
6
It is my next step actually! Thanks for confirming it may work!
