blisters.
pat
Hello. I'm looking for a sailboat to purchase, and I'm seriously considering an older Catalina 30. The other in the top running is a Tartan 3000. I've been reading the archives, and perhaps I'm misreading it, but there seems to be a point, maybe because the manufacturing of the boat that the blisters become a serious problem. When and did this occur? The boat I'll purchase will be a late '70s early '80s.
Thos Kober
Blisters..
Blisters seem to be most common in the late 70s early eighties.. sorry. On the other hand both boats you are considering are good boats. I am a Catalina owner but I have to tell you that the Tartan would be the better boat assuming the same price and condition..(Supply and Demand) though many on this board might disagree with me
F
f sondergaard
blisters
Our 25 had a few blisters when the boat was 18 years old. We repaired them ourselves and have been blister free for two years. An old salt told us years ago, that there were two kinds of boats- one that has blisters and one that is gonna get blisters. He said that any boat that stays in the water year round is bound to get a blister or two in its lifetime. What you want to stay away from is a boat that has pox! If you haven't seen the difference between pox and blisters check the bookstore. There is a book called hull and deck repair that has some good pictures!
Roger
e-mail from a friend
Pat, This is an e-mail I recently received from a very knowledgable friend. "Roger, In 1991 Donna and I brought a 84/85 Catalina 30. It must have had a 1,000 blisters from the size of a pin head to the size of a silver dollar. The boat price was depressed because of the blisters. I called Catalina and they told me that as long as water did not get into the glass matting of the inner fiberglass and that a proper repair was done the hull should be OK. I had the boat surveyed, the surveyor used an electrical meter to test for water in the matting. He found the blisters were caught in time. Toledo Beach Marine gave us a quote for $ 3,500.00 for the repairs per Catalina instructions. We gave the owner a low bid minus the $ 3,500.00 for repairs, he took it. TBM sand blasted the hull and ground the blisters in the fall and left it until later May to let any moisture dry out. Then the blisters were filled, VC Tar was used as a water proofing and the hull was painted. We used the boat for 4 seasons before we sold it and the hull was still in perfect shape. In fact we sold for $ 8,500.00 more then we had in it. So the RIGHT boat with the RIGHT blisters and at the RIGHT price may be a good buy. Catalina did not start using a blister resistant gelcoat (vinylester?) until the later 80's or early 90's. And they only use it below the waterline. If you can see the hull gelcoat below the waterline and it is gray in color, not white, it is the new resistant gelcoat. Dan"
pat
Thanks for the info. Pox? I've never even seen blisters, and I've owned several boats(mostly older Sea-Rays). This probably feeds my fear about them. Up till a few years ago, I never knew they existed. A Tartan was my first choice. I grew up about a mile from the factory. Finding in acceptable condition at a reasonable price seems impossible. But we're going cruising for 6-8 months or so through the Carribean then into the Pacific in a year, so I need one that is both comfortable for two, seaworthy and won't bust our budget.
