blister repair
I repaired about 200 dime size blisters on my 27 in 97. It is a 77 hull, #693. I used a brad point drill bit to remove the gelcoat where it was blistered, and then used a very shallow ground conventional fluted drill bit to remove the "doughnut" of gelcoat, if any was left in the blister. I then filled the crater with West System epoxy with the recommended fillers, and then sanded the hull fair and applied 6 coats of epoxy with water barrier filler. The hull coating has held up very well since then. I put VC17 directly on the epoxy for fresh water bottom paint. Good Luck!
