I'm working on hull of O'Day 19 that I bought last yr and immediately put in water. Just discovered these small bumps (< 1 cm in diameter) in several spots on hull. They sand off pretty easily but wondering what caused and how I repair. The very small cracks above the blisters weren't even visible at a glance until I saw attached photo. The bilge stayed remarkably dry and boat sailed well last yr. I first noticed bumps/blisters after washing with oxalic acid and thought they might have been caused by droplets of acid left on hull too long before rinsing ... but other reading since leads me to believe water could be permeating actual hull material. Would a good epoxy paint stop seepage if that is cause or do i need to grind out every blister and crack. Thanks for any suggestions.
