Hi Mike
Thanks for th thought.
Yes the bottom of the boat is clean and the diesel tank has been emptied and cleaned. The diesel is fresh and clean from a good source. The raw water intake is good and the raw water filter is clean and working efficiently.
Any more ideas please
David
Sent: Saturday, November 17, 2012 9:05 PM
To:
AlbinVega@yahoogroups.com
Subject: Re: [AlbinVega] Re
iesel fuel flow to engine Yanmar 3GM
Hi David - Is your bottom clean. Heavy fouling can cause poor running. Mike
________________________________
eter%40sintacha.com
To: mailto:AlbinVega%40yahoogroups.com
Sent: Saturday, 17 November 2012, 17:23
Subject: [AlbinVega] Re
David,
My suggestions:
1. Check tank and fuel to make sure it's squeeky clean.
2. Pull the tank dip tube and see if the end is clogged (some have a mesh screen).
3. Change all fuel filters (when the tank and fuel are clean).
4. Check all lines and connections for air leaks. (The "banjo" fittings on the Yanmar fuel system have a pair of copper washers to seal them, and sometimes loosen a bit, so snug them down. Be carefull as the bolts are hollow and can be snapped off if overtightened.)
5. Wash or replace the air intake filter.
If you're still having a problem you could pull the injectors and have them tested.
Good luck ... I hope you find the Gremlin causing the problem!
Peter
www.sintacha.com
