Bleeding Diesel Engine Fuel System
119
Beneteau Oceanus 321 Carters Pt.
We have a 1997 Beneteau 321{New to us this year} with a 3 cylinder Yanmar
Diesel
Is there an easy way to bleed the fuel system after a fuel filter change.
ie reducing a mess when bleeder screws are opened
Mike B
Apr 15, 2007
1,013
Beneteau 43 Baltimore, MD
Try refilling the new racor and secondary filters with fresh diesel before you spin them back on. That way you wont have as much air in the lines. When you crack open the bleed valve only open it enough to allow the air out. This shouldn't take much. Also wrap a rag around it to catch the fuel.
Mike
Feb 21, 2010
363
Beneteau 31 016 St-Lawrence river
Racor filter?
Hello,
You probably have the Volvo primary filter with a metallic lower bulb. If you change it for a see-through Racor filter (to see if there is any water in the separator), the new Racor filters incorporate a powerful manual primer pump. From there follow Mike's good housekeeping instructions.
Pierre
Beneteau 46 Georgetown YB
I installed a squeeze bulb in the fuel supply line to the 3YM30 on my 343. (Typical outboard priming bulb) After changing the filter you can squeeze the bulb until you hear fuel returning to the tank through the return line. Bleeding made easy.
