I just purchased a 2000 model 310 with a Marine Air systems Passport II A/C unit. I had the boat moved so when I tried to start and use the A/C for the first time, it did not pump any water through the system. Basically, it has lost it's prime and cannot seem to self prime. I took off the water bowl and wire filter and cleaned both. Water does flow from the seacock and into the bowl so I am getting water to that point.I only have the quick reference guide cards so I could not determine how to prime the pump. I did find the operations manual on the Marine Air website but it does not indicate how to bleed the system. Does anyone know how to do this or know where to obtain a more in-depth manual?ThanksKen
