Blackwater/ Macerator pump issue
Sep 19, 2019
17
Hunter 450 San Diego
Hello everyone. So here's one that has me scratching my head. My macerator pump is leaking but only when I have my system lined up for dumping into my waste tank. When I have it lined up for overboard discharge it doesn't. Has anyone else had this problem?
What type of water is leaking. Black “waste” water. Or water back flowing from an open thru hull?
Good possibility Larry...
Dec 2, 1997
8,954
- - LIttle Rock
A blocked tank vent wouldn't have any impact on a pump that's beyond a closed y-valve.
A pump can only leak if the seal or gasket that seals the leakage point in the pump has failed. Which means it's actually continously leaking, but doesn't appear to be when in use 'cuz waste is going through it. But if you check it several hours after use. I'm betting you'll find that it's leaking, no matter which way the y-valve is aimed (if aimed at the macerator pump, you can't use the toilet during this test).
When, if ever, have you rinsed out the macerator pump and plumbing to it? That should be done at least nominally after every use...but at LEAST several times a season.
-Peggie
Sep 19, 2019
17
Looked closer and yes one of the 2 long rods that bolt the pump to the motor had snapped off. So I'm in the process of getting a new seal kit and rods
JamesG161
Feb 14, 2014
7,774
Hunter 430 Waveland, MS
If your Macerator is a Jabsco like on my H430, then get then newest model. They had a design flaw in the bolts and macerator blade.
The newest model cost me $100 and runs fine, design flaws corrected. Piping set ups are the same.
Jim...
PS: A friend with a H450 replaced his also.
Mikem
Dec 20, 2009
823
Hunter 466 Bremerton
Jim...
What James said. I had the same issue. Three of the four bolts were broken. New pump with the upgrade fixed it.
Jan 12, 2016
272
Hunter 410 Ladysmith, BC
The raritan macerator is the exact same mounting footprint and power draw as jabsco if anyone is looking at a better replacement.
Jun 1, 2009
1,841
Hunter 49 toronto
Jim...
To that point
The original rods were brass, and they just rotted out. Jabsco saved 3 Cents by doing this, and it was a disaster.
The new rods are stainless
fero
Jan 15, 2010
122
Hunter Legend 40.5 Victoria
Can you get the stst rods separately? I had to canibalise the spare pump left by th PO for the same issue.
Thanks.
Mar 6, 2008
1,356
Yes, the rods can be replaced with stainless steel screw rods. To keep them from breaking add a 4" hose to the intake of the macerator.
Jun 1, 2009
1,841
Hunter 49 toronto
Honestly, I never would rebuild a mascerstor. Tried it once years ago, and just the tiniest crack in the seal stinks up your boat.
It’s a $100 replaceable part, and it’s best to look at it that way. With the new stainless rods, you’ve got a good 5 years on it easilly.
JamesG161
Feb 14, 2014
7,774
Where do find 100 dollar macerators?
I got mine during WestMarine "price match" sale. $100+ tax. I didn't ask where they found the match.
Perhaps timing was everything?
Jim...
Jun 1, 2009
1,841
Hunter 49 toronto
Defender has the best prices on most things. Rebuilding a macerator just doesn’t make sense. Jabsco charges a lot for the parts, and it’s an awful job. Plus, it’s just never going to be as air tight as a new unit. Just not worth the headache.
