Some time back I mentioned that I wanted to replace the galley faucet and the fittings nearby, which leaked. The problem was all the cabinetry making access difficult. Today I made a bit of progress in that regard by removing a panel on the port side of the sink's cabinet, alongside the companionway stairs. Had to remove six concealed screws. There's another panel behind that, which I cut using a Bosch Multi-tool. This has given me easy access to the connectors and the underside of the faucet. I'll attach a picture of the new opening, which will be easily resealed, I think. I'll add a few more pictures to help clarify what I've done and how it'll go back together. I'll probably put in a Whale faucet, like I put in the head, as it is attached from above and easily removed and repaired.
Waiting on some bits and pieces to finish the water heater install. I'll update that thread once more progress is made.
John
John
