Birds in the Mast
49
Lancer 25 MK 4? still searching this Trailer sailer,,, Louisville
Hello everyone,
I have run into the issue of realizing that birds have used my mast as a home:confused:,,, they are not residing there presently, so how can I get the remnants of the former home out of the mast, it is near 15 or so feet up into the mast:doh:. I have run stiff wire through the hole of the mast light at the speaders and I have tried reaching up with my boat hook to try and pull out what I can.... there is still more pine needles etc in the mast,, Any suggestions?
Thanks a lot...
Rod
BobM
Jun 10, 2004
3,269
S2 9.2A Winthrop, MA
Hope this helps
Have you tried adapting a smaller tube to a shop vac? You could easily snake it inside the mast to get out smaller debris and pine needles will at least stick to the end allowing you to pull them out.
Ross
Jun 15, 2004
14,693
Re: Hope this helps
Fire? ;) is the mast on the boat? Chimney sweep brushes would work if both end were open.
Water hose? You can get a nozzle at ACE hardware that will up the pressure (it's got a small hole for an outlet) and you may be able to "flush" them out! :):):)
Feb 10, 2004
4,184
Hunter 40.5 Warwick, RI
Damn birds! I feel your pain....
Rod,
Since you were able to get you boat hook in the mast, you must have the mast off the boat.
I have had the problem with birds nesting in my boom when it is on the boat, and both times (yes, sometimes I can be a slow learner...) it took me HOURS of effort to remove the nest.
I was most successful using a wire snake to break up the nest as much as possible, and then I inserted a hose at one end and used the hose as a ram with the water running to further break-up and flush out the debris. I had to tip the boom down as much as possible to get gravity to help. My boom has a outhaul block system inside so there was lots of "stuff" for the nest debris to get caught upon.
A vacuum hose with a shop vac was not helpful for me because I could not get the smallest possible hose into my boom. You may have different luck with the open bottom of the mast.
I now cover and seal securely both ends of my boom as soon as my winter cover comes off to prevent a THIRD episode.
Dec 9, 2006
694
Oday 22 Hickory, NC
My first thought was this...what is wrong with birds living in the mast? What would the harm be?
Jack
Jul 19, 2009
49
The Mast is off the boat I am rewiring it for the lights.
The shop vac idea sounds good tomorrow I will probably try that one 1st,
as for the chimney sweep method, both ends are not open, so it would not work...
The water hose may work if I prop the mast up on my garage roof, ( it is in the driveway right now ) especially after the shop vac loosens things up??
I really do not want to have to try and get the nest out of the entire length of the mast (measured it today 27 feet 7 inches in length) So I am hoping that the shop vac works, I was able to knock most of it out with my wiring installation and the boat hook,....
As for the "what is wrong with birds living in the mast? What would the harm be?" well, no harm for me or them as long as the mast is just sitting across the boat and not in use, but if they are nesting in there in the spring and I want to go out, that would mean disturbed nest and smashed eggs or dead birds, so it is in the best interest of my boat (animal urine and feces are not good for metals and for that matter most materials) and the bird's lives for there to be no nest or nesting material in the mast for them. My boat is a trailer sailer, so, the mast is down when in storage and on the trailer, hope I was able to clarify my point ....
Thank you to all of you who made suggestions,....
Rod
Jul 19, 2009
49
I know you were just asking, I just wanted to explain my thought process. Don't worry I'm not mad, just replying to all of the replies I received, and I appreciate all of them. If I came across as gruff, I apologize for that.
take care and happy sailing
Rod
Jan 27, 2008
3,092
ODay 35 Beaufort, NC
What kind of birds were they?
Some species of birds are protected as endangered species. You may have to give up sailing in order to not disturb the birds.
Also if they were turkey vultures they might scare the heck out of you, while a parrot might make a good pet to talk to and teach tricks.
I too had birds nest in my boom and found just wrapping a few wraps of rigging tape across the hole and over the end of the boom they no longer bothered me. Most likely chickadees as the hole they were going through is pretty small. i just flushed it with a hose and all the stuff came out. at least the boom is easy to work with.
Good luck with cleaning it up.
BobM
Jun 10, 2004
3,269
I had some nesting woes yesterday too
My Wife took my niece out to a tea shop for her birthday. Five minutes before leaving an hour late she asked if I thought it would be a problem if she took her Jag, a 1989 XJS I bought for her off ebay a few years ago (to off set some of my guilt over all the toys I have). So much for my relaxing morning. :bang:
This spring I had dug a softball size mouse nest out from under the cruise control bellows (visible just behind the AC pump in the middle of the photo). It took me about an hour. I had warned her last week that the garage had a new resident, later found dead outside the garage a few days later, but not before assaulting a role of shop towels. So when she asked, I told her to wait until I checked under the hood. Sure enough there was another nest. She must have given the mouse a heart attack :eek: when she took it to work earlier in the week. That V12 sounds like a jet engine when you first start it up. Under pressure I cleared the mouse nest out in about ten minutes flat using two long screwdrivers like chop sticks and then blowing out the remnants with compressed air. I had used the shop vac previously, but sill me, hadn't kept whatever adaptor I had kludged together to get the hose down to a small enough diameter to fit in. I have attached a photo of a nicer jag as reference. Please note that, in my experience, the phrase "British Engineering" is usually preceded by an appropriate expletive.
992
Oday 25 Gibraltar
How big of a hole do you have in your mast or boom for birds to be nesting in it?
Vacuum? Heck, take the ends off and clear it out with an air hose or leaf blower
Rich
Joe
Jun 1, 2004
8,258
My bird experience...
If I don't tie the end of my mainsail and cover tightly in the spring time, a family of finches will set up housekeeping in the folds of the sail. The birds take turns standing guard after the eggs are laid.... they are very cool to watch as they try to draw you away from the nest or chirp loudly to distract you. I didn't realize what they were doing until I hoisted the main at the dock one day before going for a single handed sail and the nest popped out onto the dock finger... broken eggs.. the whole deal. Wow, did I feel guilty... but the damage had been done so I left the nest on the dock and took off.
The following year, the birds chose my boat again for their home. I checked under the mainsail cover as soon as I saw the parent guarding the area. This time I called a finch expert and she told me the total time from egg laying to hatching was 2 weeks and it would take another 3-4 weeks for the chicks to outgrow the nest and fly away... So... still feeling the guilt of last year I waited and observed, even took some pictures of my adopted family each week. The last week things got messy as the family had become so crowded and they would poop over the side, so I put paper down... just like a bird cage. When I came back the following week and found the nest empty I was a bit sad, I was hoping to be there when the kids took to their wings... but I was happy they survived the predator birds in the area and glad that I could go sailing again.
After telling her the story my bird expert told me that if the birds will build a new nest and lay eggs again if things get destroyed or disappear. Actually, many birds are like that... that's why hens lay every day... hmm.... I didn't make that association.
Anyway, I found a half-finished nest in there one year and had no problem disposing of it even though the propsective parents were pretty pissed. I just make it a point to close off the end of the sail and cover which I've made easier by adding extra snaps in that area.
Joe
Jun 1, 2004
8,258
Big, beautiful birds....
As a follow up to my finch story... here's something you might find interesting.
The neighboring marina in our basin has a large, old fashioned trawler type powerboat with a mast used for a stabilizing sail. A family of ospreys has had their aerie on the top of this mast for as long as I can remember. It is a very large nest, and unlike the finches, they live there year round. Each spring you could observe the parents bringing back fish and whatever to feed the growing chicks in the nest. I would sit in my cockpit and observe through my binocs..... Occasionionally you'd see these magnificent birds hunting near our dock, perched on a parking lot light post or the spreaders of a sailboat's mast, looking for the small squirrels that inhabit the area. All my dock neighbors were mesmerized by these magnificent birds of prey. The are nobel, regal creatures.
I was told that one of the reasons the birds had remained in the area for so long was that it was illegal to remove or destroy their nests. The boat owner has not been able to move his vessel because of this....it's been sitting in the same spot for at least 10 years.
Well...... to my astonishment... this spring I noticed the nest was gone. I asked around and was told the owner got a permit and with special assistance the birds were relocated to another area.... At least that's what I hope really happened. If it had been my boat I guess I would have tried moving them long ago... but other wise the presence of the ospreys in our lagoon was a beautiful thing while it lasted. I will miss them.
Jul 19, 2009
49
Those are some interesting stories and methods of cleaning out the mast, I ended up cleaning it out well with the shop vac, and boat hook, I am guessing that my mast is about 7 inches across at the widest point, it is oval in shape... The birds nest I cleaned out was not being used, and it should not have been any type of large protected species, after all it is in my driveway in KY, the hole they used is now filled in with a very large plastic cup,,, fit tight and is reusable...
Thanks for the post everyone!!
Ross
Jun 15, 2004
14,693
Re: Big, beautiful birds....
Joe , Come to Rock Hall, Md. The Ospreys nest on every navaid and on many bimini tops. I watched one pair playing around the strings and flashing ribbons on one boat.
Jan 10, 2009
590
PDQ 32 Deale, MD
Be sure to close all of the useable holes when you are done.
Yep, had the same problem in my boom, and the problem there is that they jam the internal reefing tackle. Boat hook and hose.
I took the time to make bird-proof covers for all of the openings they were using (there were several) and then they tried nesting in my sail covers! Several broken eggs later, they moved on.
