Biomimicry
10,253
Pretty kool, but what a trash collector ! Every piece of string, weed, crab pot line, etc within 2 miles would get hung up on the ridges.. Probably OK if you have a swing keel that can be pulled up to clear it while under way.
All fun and games 'till someone puts an eye out on them bumps!
DannyS
May 27, 2004
933
Beneteau 393 Bayfield, Wi
I have a friend in our marina that modified his Freedom 20 by adding "tubercles" on the leading edge of his rudder and keel. He did this with golf balls that he cut in half and then epoxied and faired in place. He was convinced it worked. We sail on Lake Superior...no crab pots or weeds to worry about.
He's a little bit crazy though...in a good way.:D
walt
Jun 1, 2007
3,556
I think that particular whale feeds on small fast schools of fish and needs to turn quickly - ie, it needs the fins to generate very high lift without stalling. Past discussion on this (I believe) came to the conclusion that the structure on the fins was possibly more about not stalling under high lift conditions than good lift to drag. Not exactly what National Wildlife mag says..
I think we are generally more concerned about higher lift to drag ratio.
caguy
Sep 22, 2006
4,004
I would think that while it may not benefit the keel or dagger board it could make a difference on the rudder. It may reduce stall on a hard turn or increase steerability at lower speeds.
May 23, 2007
1,306
Catalina Capri 22 Albany, Oregon
Could you test with a pool noodle?
It might be interesting to cut a pool noodle down and tape a few pieces to the front of the rudder to test that theory . . . it would require good tape and an unpainted rudder though.
r.oril
Oct 29, 2008
586
MacGregor 26D and Catalina 30 26 - 30 Lancaster, CA
I have the original rudder for my Mac 26D that was replaced by a new Ida Rudder. I like your "noodle" idea.
