G
Greg Jones
The Barient #8 winches for my jib furler sheets tend to bind and get jambed when pulling either sheet. The port winch moreso than the starboard but enough on each to be a pain. I have loosened the retaining bolt each time which frees the winches up but it only will tighten back down after a couple uses. I have cleaned each winch thoroughly but that hasn't solved the problem. I have seen some winches with a washer on the reatinaing bolts, but there never were any on mine that I can tell. Any help would be appreciated.Thank YouGreg JonesS/V Encore
