Hi All,
I just bought my first "big" boat, the Catalina 30 mkII. Moved up from a Cal20!
Everything about it is wonderful, but I'm having a helluva time with the halyard and furling lines. They seem WAY too difficult to pull out.
The main - I've checked all the blocks and feeds, and everything appears to be free and move on its own, but when I use it from the cockpit, I can get the main about 1/4 way up and then it's too hard to pull from the cockpit. I can walk over to the mast and pull down on the halyard directly and it seems "normal" from there. It's not sticking in any one place, I think it's just too much friction over all, and I'm not sure what to do to make the most difference.
The double decker deck blocks all turn freely, but they do appear worn to me, meaning the wheels are wobbly, as if they've worn in their centers. The mast base block appears "normal".
Should I just go get some tri-flow and start spraying everything?
The jib furling line - goes through a lot of blocks too, and seems a bit tough to get out, but maybe lube also?
Where do you get replacement deck blocks?
Thanks all!
Thanks all!
