My boat has a bimini installed and the aft port deck mount hinge sometimes slides forward an inch or two on the track causing the bimini to get out-a-wack.
The issue is that the two screws that hold the hing by being screwed into the Teflon sliding block "inside the track" have stripped out the threading in the Teflon block, and so the hing is loose, you really cant screw into Teflon without stripping it out anyway, in an effort to tighten the hing from sliding forward.
The first pic shows the hing removed with the Teflon sliding block exposed, the second is the opposite side of the bimini all assembled.
