Bimini measurements for 23/2
Oct 29, 2020
5
ComPac 23 Annapolis
I have a Compac 23/2 and would like to install a bimini. Will a bimini measuring 46" height, 78" width, 72" length fit on a 23? If not, what are the correct measurements?
Oct 29, 2020
5
ComPac 23 Annapolis
Thank you. I’ve done these measurements but was hoping that someone who actually installed a Bimini on a 23 could provide some guidance. I’m primarily concerned about the height.
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
About height............make it as tall as you can without it hitting the boom, since the ComPac 23 has a boom that extends far into the cockpit.
Oct 29, 2020
5
ComPac 23 Annapolis
Great advice. Thank you. Fortunately, the boom on the 23 sit high so there appears to be loads of clearance. With a bimini on a track it should be adjustable so that can be stored a stern.
Oct 29, 2020
5
ComPac 23 Annapolis
For other C23 owners, bimini's with the dimension 46"h X 78"W X 72"L fit. Although close, the boom clears the top of the bimini.
