Bimini/Mainsheet interference
78
- - Edmond, OK
First sail in my new 2004, and immediately discovered a suprising problem: The bimini comes far enough forward to prevent hooking up the mainsheet to the intended eye on the boom. Suprising because I find it hard to believe that you would have to chose between having the bimini up and sailing. Is this by design, or do I have an oddball? If by design, what have you done to correct the interference? The only thing I can see is installing another eye about 2 feet forward on the boom, which will obviously decrease the mechanical advantage for the mainsheet. Thanks for help and suggestions. Mike
