bimini for an O'Day 222
4,881
Oday 222 Dighton, Ma.
Just a reminder: Each strap has a spring mounted hook which makes it easy to detach. I usually only hook one if having to move around the deck or docking. Takes less than a second to drop.
A set-up like that might work for me after all. I'd really need to study it before I'd invest in one. A lot of times when we're out there in the heat with the sun bearing down on us, I attach my golfing umbrella to my stern rail and adjust it accordingly.
Jan 18, 2010
10
Oday 222 Port Saint Joe
Bimini O'Day 222
No, as a production boat there are weak points that should not be pushed. After all when sailing it's not about speed. Usually try to keep her at a 10' to 15' heel. The crew seems to like it too. All I do is check the bolts and tighten down when needed.
One last note: Soft spots can develop any where on deck and should be checked for often and repaired. Chain plates, etc. are holes through the deck and must be checked. I would have preferred O’Day have designed theirs (back in the day) like the Pacific Seacraft (Flica) version (on the sides), but let’s face facts. The O’Day’s are a fraction of the cost and use standard accessories, and if well cared for will last a lifetime. My first step, if an upgrade was needed would be to replace the back plates with longer stainless steel ones that would need to be made to fit. Now I’m going to share a little secret that works for me (please no critic’s on this procedure). When I winterize NORA, she gets a light spray of silicone spray on her deck (tire shine & wet look automotive products). The silicone keeps the rubber seals soft and creates water barriers on any micro fractures in the gel coat. Caution here, silicone is very slippery. Silicone works better than wax although each spring she gets a good wash down, wax, inspection and does a great job of bringing life back to an old boat for another year. I don’t recommend this procedure to any one. It is simply an experiment to see how long NORA will be around.
Jan 18, 2010
10
I did a little searching and found the link: http://connect.taylormadeproducts.com/cgi-bin/standard.pl The standard bimini with no modification works:
Bimini BoaTop - 73" - 79" x 4' x 36""Allows 7" for the boom to swing"
