Bilge Water
gary
Jun 5, 2004
86
- - Sally Rose
I frequently find water in the bilge of my Hunter 22. Not a lot - maybe a quart or two once a week to ten days. I am mystified as to how this occurs. I don't believe it can leak in from outside the hull. The water here is never above 52 - 55- degrees F even in the hottest months and I have considerable condensation in other parts of the boat. I wonder if this could be the culprit.
thanx
garyg
7,743
Alden 50 Sarasota, Florida
leaks
It is often said that all boats leak, even those you think don't...
Common sources include the stuffing boxes (rudder post, shaft), mast step, windows/hatches, deck/keel joint, keel bolts, etc.. Condensation is unlikely except in very cold weather when you have a source of heat inside the boat.
If it concerns you, you can thoroughly dry the boat and sprinkle baby power around the likely sources and wait to find a residual trail of water.
Jack h23.5
Water in the bilge.
I was getting about that much each week also on my H23.5. I installed a dehumidifier and leave it running 24/7. It sucks out about a gallon of water a week from the air in the boat, and my bilge is bone dry now. I can also leave towels, sails, cushions etc inside without any mildew showing up. I can even hang wet stuff to dry while I'm gone.
Jun 3, 2004
232
Cockpit and anchor well drains...
I imagine your H22 is much like my H23... I discovered that the water I was finding was coming from a small leak in the cockpit drain hose. I would take in a little water every time it rained. I would even take in a bit as water washed up the thru hull from wakes as she was on her mooring ball. After I got busy and took a hard look at sources I also discovered a small leak in the anchor well drain as well as from the lower pintel.
