John Smolinsky
On our 1979 H 27 ,as expected the bilge collects water.. .from who knows where. This is not a problem, as the bilge pump pumps most out,but not all. The problem is when sailing and in particular when heeling over, the bilge water sloshes into the storage areas below the side berths. The water flows through the hole where wiring is routed so it seems unreasonable to seal it ( in case access to wiring is necessary). Once the water is in the storage area it does not flow back because of the contours and elevations when sailing flat. Have any of you devised a solution?
